Modular Everyday Pen Organizer
4.0
Rated 4.0 out of 5 stars
3 Reviews
Regular price $14.99
Looking for a way to organize all of your paint pens, alcohol markers, and sharpies? This laser cut organizer measures 17.6" tall, 10.7" wide, and 4" deep, with a 6" bottom. This is an excellent choice for artists and crafters who want the freedom to arrange their supplies exactly the way they need them. (If this is too big for your space, there is a smaller version as well).
6 x 10.7 x 17.6 in
Mallet
Assembly
Based on 3 reviews
Total 5 star reviews: 2 Total 4 star reviews: 0 Total 3 star reviews: 0 Total 2 star reviews: 1 Total 1 star reviews: 0
Customer-uploaded media carousel. Press left and right arrows to navigate. Press space or enter to open more details.
Slide 1 selected
3 reviews
  • MA
    Morgan A.
    1 year ago
    Easy assembly & clean cuts
    I built this as one of my first projects abs v it tured out wonderful.
  • C
    CMadok
    1 year ago
    File works great with Baltic birch or Medium Draftboard
    I cut this file from 1/8-inch Baltic birch and it worked perfectly. I do not think this will work with proofgrade medium plywood since the plywood is a little thicker. It should work perfectly with medium draftboard however, since it's the same thickness as the BB. Light plywood may be a little bit thin. I thought the file arrangement could've been a bit better to save some material, and on one of the files I did rearrange things and saved about 3/4 of my board.
    In all though, this file is pressure fit. I had to hammer the pieces into place and I only used glue on the frontwall of the base. So if you are using anything thicker than medium draftboard, this file will not work for you.
    I've got paint pens, alcohol markers, wood glue bottles, adhesives, jewelry supplies, etc store in here with plenty of room to spare. Great organizational tool for my desk. Only thing that could've made it better would be a a section deep enough to hold my mallet, ruler, and scissors.
  • M
    Melissa
    Rated 2 out of 5 stars
    1 year ago
    Nice large item
    after printing all 5 sheets of pieces I found out that they would not go together. Would probably work great if using glowforge-proof grade wood but I wasn't. Definitely verify that your wood is the correct thickness before cutting as mine was slightly different than the proof grade, Not by much but enough that I couldn't put pieces together.
Reviews LoadedReviews Added
