1 of 1
Basswood Plywood - UK
Masked, Finished
Choose Size
Choose Thickness
Regular price £26.00
Regular price £0.00 Sale price £26.00
Proofgrade Basswood Plywood is so clean, light, and soft, you can engrave wonderfully stark details on its surface. It’s favored for picture frames, woodenware, and novelty items, but can be used anywhere you’re searching for a pop of brightness. The micro-thin basswood layer is creamy white in color, making it a perfect choice for a high-contrast inlay with darker woods like Walnut.
About Proofgrade Plywood:
Proofgrade plywoods are custom fabricated with an engineered wood core surrounded by a micro-thin layer of natural hardwood, resulting in a strong, beautiful, and versatile material that you’ll use every day. We match our hardwoods, plywoods, and veneers, so you can combine all three for a consistent and professional look. Each board is coated with a furniture-grade semi-gloss finish, and protected with a removable paper sheet, and encoded with a barcode for perfect settings. As a result, each print looks incredible straight out of the laser. Proofgrade plywood cores are engineered to be predictable from board to board, giving you the same consistent results from every print. The beautiful hardwood outer layer is a natural product, so each board will have a distinctive pattern and grain all its own.
CA Residents: Prop 65 WARNING
What is Proofgrade?
